It is currently Mon Aug 11, 2025 2:39 pm
PostPosted: Thu Sep 15, 2016 7:27 am
Hi
Little question, when sanding for example a saddle on sandpaper on a flat surface do you allow the dust build to act as a lubricant or do you tend to move it on fresh areas for quicker sanding ?
Like I said not important but wondered if I'm missing a tip :) :) :)
PostPosted: Thu Sep 15, 2016 8:00 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Regardless of what I am sanding, I always brush or vacuum the sanding dust off. If you don't clean it off, you are just re-sanding the sawdust into finer dust, and packing the sandpaper with it. The reason it feels like it is acting like a lubricant is that the saddle isn't coming in contact with the sandpaper like it should.
Alex
These users thanked the author Alex Kleon for the post: cablepuller1 (Thu Sep 15, 2016 1:03 pm)
PostPosted: Thu Sep 15, 2016 10:18 am
First name: George
City: Seattle
I keep the paper and the piece as dust-free as possible, mainly because I find that doing so makes it easier for me to see what it is that I'm doing.
George :-)
These users thanked the author George L for the post: cablepuller1 (Thu Sep 15, 2016 1:03 pm)
PostPosted: Thu Sep 15, 2016 12:59 pm
Keep it clean, abrasive cuts better.
Use a Abrasive Belt & Disc Cleaner (or a rubber/eraser) to lift the dust out - cuts better for longer
These users thanked the author Colin North for the post: cablepuller1 (Thu Sep 15, 2016 1:03 pm)
PostPosted: Sun Sep 18, 2016 10:24 am
They are building dust collection into a lot of sanders these days. It is done for more than just dust control. Sand paper often clogs up before it is really worn out. I have even washed some (mylar backed) sanding discs and reused them. With some discs costing $4 apiece extending their life where possible helps keep costs down.
These users thanked the author Clay S. for the post: cablepuller1 (Sun Sep 18, 2016 10:38 am)
Users browsing this forum: DennisK, pkdz, pullshocks and 17 guests
